E-MTB conversion kits are out on the market now and they seem quite legit, not cheap Chinese kits you might find on Amazon or Aliexpress. Bimotal and CYC are two I saw so far.
You in the market for something new?I'm really liking Cannondale's new Moterra SL.
Maybe. You'll know in November.You in the market for something new?
My prediction is it will be Pivot, 8 in 10 friends buy Pivots 🤣Maybe. You'll know in November.
I'm not a fan of Pivot for one dumb reason, they use superboost in the rear. I like to swap out wheels from time to time of different types and they're all 148mm in the rear so I can't do that with a modern Pivot.My prediction is it will be Pivot, 8 in 10 friends buy Pivots 🤣
You could demo my SL or even my LT, if you wish...😀I'm not a fan of Pivot for one dumb reason, they use superboost in the rear. I like to swap out wheels from time to time of different types and they're all 148mm in the rear so I can't do that with a modern Pivot.
I’ve ridden it a lot.I'm really liking Cannondale's new Moterra SL.
Get over it. 157 makes for a stronger rear wheel. The don’t do it to be difficult. They do it because it is a better solution. It’s far easier to build around a 148 hub, but it makes a way less solid rear wheel.I'm not a fan of Pivot for one dumb reason, they use superboost in the rear. I like to swap out wheels from time to time of different types and they're all 148mm in the rear so I can't do that with a modern Pivot.
I could kid myself and say I can ride as long and hard as you younger shredders but realistically I just can't. Even with a range extender on my Rise my body will run out of juice before the battery will and that's with ~540 or 560Wh total? Even if my legs can handle it with the motor assisting, it's the rest of my body (back, arms, butt, neck, wrist) the motor doesn't help with that limits me. Last year in Bentonville I had to tap out at around 24 miles. I say all that to say I don't think I'll ever need more than 600Wh of juice so that's not an issue for me.I’ve ridden it a lot.
600wh battery w no range extender option is a deal breaker for me.
Rides well though.
I rarely come home w/o crushing the 750wh on the shuttle am.
I'm sure all of those benefits to 157mm over 148mm are true but none of them will be realized by me with the way I ride. I'm as stubborn as a mule so unless my list of pros and cons leans heavily towards 157mm, I'm not buying it. BTW, when I said I'm not a fan of Pivot for one dumb reason I meant my reason is dumb, not the superboost spacing.Get over it. 157 makes for a stronger rear wheel. The don’t do it to be difficult. They do it because it is a better solution. It’s far easier to build around a 148 hub, but it makes a way less solid rear wheel.
You can take out my am one day if you like. But be ready to buy. I’ve sold a lot of these to people who were convinced after just one ride.
These are going to the race motor soon which makes this a better option still. Might flip mine to go for that. Or maybe got for the new LT which is mullet. That has some advantages for my short ass legs. 🦵
I can contest as the wheel destroying lurch that I am.Get over it. 157 makes for a stronger rear wheel. The don’t do it to be difficult. They do it because it is a better solution. It’s far easier to build around a 148 hub, but it makes a way less solid rear wheel.
Maybe what I need is one busted rear wheel to convert me.I can contest as the wheel destroying lurch that I am.
Since going e I've destroyed both original wheels, then 2 handbuilts and 1 purchased. All rear. My take is 1. I'm a lard 2. I do not finesse 3. May need 36 thicker spoke rear wheel. These bikes are 20# heavier then the parts are designed for. It's like drivetrains for regular bikes just don't cut the mustard. I really should be a tester because I've been breaking shit for 30+ years.Maybe what I need is one busted rear wheel to convert me.
Is superboost the now, again?Get over it. 157 makes for a stronger rear wheel. The don’t do it to be difficult. They do it because it is a better solution. It’s far easier to build around a 148 hub, but it makes a way less solid rear wheel.
the new AMs will have the Bosch Race? 👍Get over it. 157 makes for a stronger rear wheel. The don’t do it to be difficult. They do it because it is a better solution. It’s far easier to build around a 148 hub, but it makes a way less solid rear wheel.
which mean the g4 ams with a ride build are now under 6k. We have em on hand and it basically the same price as buying a switchblade. Not that this makes them cheap per se, but in line with the less desirable brands.the new AMs will have the Bosch Race? 👍
It might be worth looking at the new Orbea Rise w/ a 400 wh battery and a range extender. This allows a really light setup when on a shorter ride.I could kid myself and say I can ride as long and hard as you younger shredders but realistically I just can't. Even with a range extender on my Rise my body will run out of juice before the battery will and that's with ~540 or 560Wh total? Even if my legs can handle it with the motor assisting, it's the rest of my body (back, arms, butt, neck, wrist) the motor doesn't help with that limits me. Last year in Bentonville I had to tap out at around 24 miles. I say all that to say I don't think I'll ever need more than 600Wh of juice so that's not an issue for me.
