Did a full loop today and have noticed some areas which are in dire need of some chainsaw lovin'. I started out at canal lot and went blue to red, cross S. Middlebush Rd., to orange to 27 lot. Then came back orange to red to Canal lot.
I'll try to take you through this in order, the first thing I noticed is the new found fun and excitement all the work that was put into clearing and retouting the blue trail up to the blue/yellow intersection. All of you who sweat and bled to accomplish what has turned out to be the worst part of the damage, please know your work was well appreciated! From the blue/yellow intersection on still needs a crew with a chainsaw to remove numerous downed small trees which block the trail. The field sections look good(of course) until you get to the small through the woods section(right before those four flat top bridges) there is a huge tree that blocks the trail(go around is an option). Continuing on, and over the long bridge across the muddy area, there is a huge tree blocking the trail that needs to be chainsawed. From there to the metal bridge looks good but has a load if sticks and branches to be removed.
Once you cross over South Middlebush, it's a disaster! Right at the entrance is still some downed trees which should be removed and several downed trees and huge branches all the way to the new long bridge. One you cross over the concrete bridge it gets worse. From that bridge to the arched bridge lies several huge trees that need to be removed with a chainsaw and crew. One in particular lies directly over those left/right double burms. From there on it all looks well until you get to the "billy goat section" near the 27 lot which has tree that needs to be cut blocking the trail.
On the way back I took the red trail(expressway) and it looks good until right before the red/ orange intersection where there lies two trees crossing the trail (go around?)
As I bear left at the blue/red intersection, I took the red all the way back to the the canal lot. Small maintenance would be the best way to describe it from that intersection to the red/red intersection. The last 3/4 mile of the red where the big dips are is a disaster and needs a lot of help and saws. It is unrideable in that section and I strongly urge no one ride it until it has been cleared.
On another note, I met a nice lady in the canal lot when I got back and would like to know if she could please send me a PM and a friend request.
That's my report - enjoy the trails and be safe!
