2 Fatbike newb questions.
YOU'RE STILL RUNNING TUBES!!??
I would've never let the bike leave the store with tubes in it. TUBES!!??
hahahaha... I know. I'm sure I'm guilty of multiple MTB/Fat Bike rules violations, but I'm learning. I did remove the dork disk from the back wheel and with your guidance today, now I have an MTB helmet, so I won't be made fun of.
One last question....
Clipless pedals? Is everyone running them? I've got SPD's on my bike now, but I'm wondering if I should temporarily switch back to flat pedals as I get used to riding on some more technical stuff.
Ride whatever pedals you like. I run clipless on all my bikes, including the fatty. But, in the winter, I change over to flats because the snow gets packed in the cleats and makes it a PITA to get clipped in.
I run flats on my fat bikes. I don't feel like I'm giving anything up by using them and gain the ability to stab my foot down if I push the front tire in a turn. Good pedal and good shoes make a difference as does heels down technique. I do use SPD on my other bikes and have found flat did not work well on my SS rigid 29'er. Bounced around way to much.
either way is fine
If you're comfortable on flats great.... but if riding trail on flats is new for you... maybe you should stick to SPD's or take some precautions. Flat pedals to the shin's smart a bit... just ask Moose.
I got a nice boo boo today
First is @pooriggy tape up job.
Next is a pic of the gash
View attachment 40992 Last A Little Close Up
Thanks to everyone that helped me out
From the awesome tape job @pooriggy
The wookie shoulder to lean on @Frank
The extraction ride @sk1er18
The bandana @Brian Snyder
And Matty, Jim, Norm, Magic and whoever else was making me laugh.
Thanks
Yea... obviously, the overall answer is "run what you feel comfortable with or want." I wasn't really looking for that. I was looking for some reasons for running one over the other.... which you hit with the snow aspect.
either way is fine
Coming from the road, being clipped in obviously pays huge dividends in efficiency and I can definitely see some benefits in having the same efficiency in loose conditions like being able to put down even power through the whole pedal stroke when climbing, but there's also a piece of me that thinks I might be more comfortable learning how the bike will handle in loose conditions while not being clipped in at first, so I can put a foot down easier if I need to... Devil
s advocate says that I'll never get used to feeling clipped in in techie conditions if I don't just jump in the deep end and go for it... so there's that too. I'm probably just over-thinking this all way to much because this weather is putting a damper on me getting out and actually riding.
I rode spd on mtn bikes since mid 90s, when i first tried flats recently, I thought they were terrible. I could not keep my feet on the pedals, couldn't spin, couldn't bunny hop. I would hit a bump, my foot would roll the pedal forward and come off. They only lasted a few rides. About a year ago, I tired them again because I had a few bad crashes in tech stuff and some "ride the bike into the ground" wash outs. Over time, I learned how to ride with them, just like I learned how to ride SPDs when they first came out. They feel more stable then the spds, I can use different foot positions. And with heel down technique, I can spin. plus I have the added safety of being able to step off the bike when things go wrong
I think the whole SPDs efficiency is overblown, especially when it comes to mtn biking, you aren't spinning along at a nice smooth cadence.
Flats, fat bike and droppers are all things I said I would never use....then I tried them and saw how great they were
But is the goal not to do so? Smooth is fast. Ability to keep spinning while bouncing around without your feet coming off the pedals is fast.
I think bike,rider and trail has more influence on spinning than pedals. Its really coming down to personal preference, you can't go wrong with either
Well written post and I can't disagree with any of it. I'm not actually asking if clipless is better than flat, I'm 100% certain it is. As a road cyclist, I'm 100% comfortable clipping in and out, so when I got my fatboy I threw clipless pedals on immediately. I'm actually wondering if maybe I jumped the gun a little bit and I should switch back to flat for a few months as I get used to being off-road, which is essentially the order you describe in your post, learning to ride off-road on flat pedals for some time before switching to clipless.
