OOS MOGA
I'd be up for a Sunday ride at RW. Let's confirm on time.
8AM good at Ryerson?
And I am expecting someone to take a dirt nap! @arangov3?
I should be able to make 8ish. Just let me know what trails or what altitude and mileage we want to do and we can plan a ride or if someone that knows the park better is there they can lead.
@arangov3 did pretty well last week especially on the downhill stuff so he should be good although I believe he went down once when he wasn't even moving
Max is usually good with the downhill stuff. That's one of the reasons why he went with a 34t chainring so he can pedal when going down.
I think we are all good for 10/10
I have to stay local this weekend so I'm out for MCBP. If the 6mile ride still goes for Saturday, I can lead or sweep but I can't get there until 8:30. Just throwing that out there in case it helps.
Come to RW on Sunday.
Why not just join the OOS MCBP on Saturday? If too tame.... you should get together with @oobaa47
Friday I'll be at Creek....great vibe, no lines.....
I might be able to join you at Ringwood Sunday morning depending on the time.....8am might be doable if the ride isn't too long....
10 miles 1000ft
Ok, I def have a route, but it would probably be closer to 10 mi 1200-1500ft. it will probably take at least 3 hours we would hit cats nest, go to the top of white up to the lookout and all the way back down to the top of warm puppy then back to Ryerson. Should be just under 10 miles and over 1000ft and a lot of fun. There are a lot of other options and if we are feeling very adventurous we can go to the top of white the back way up Hoeferlin which is really raw and doesn't see a lot of maintenance so may be some down trees.
Max and I did a similar ride this weekend getting to the lookout on the top of white is very technical so it is a good time and a beer to anyone that can climb the final section to the top of white.
I am also open to other rides and exploring as well, it may be a lil slower going but there are a bunch of great trails in that park to find and ride.
Bpaze: when you say the top of white, are you referring to the top near Pearson Ridge Road, or are you referring to up by ilgenstein Rock? Where is hoeferlin?
H
How many beers? 🙂
I am talking up whit rock garden to the viewpoint on top o the rock. hoeferlein is the yellow trail up there it is the back way to make going to white a loop
