Bearing Press Set
mtn
Anyone have a used set or a cheap recommendation? Like amazon prices.
I do have a wheels mfg bb press, so assuming I just need the cup things?
Also need recommendations of the bearings. Main ones are Rolu 6804, but I’d rather put something better in there (not chinese).
Have you tried Amazon?
Honestly the drifts are the simplest part and any set should work fine. Hell even plastic drifts could probably work for bicycle use tho I would recommend at least al. They are literally just solid metal spacers with a hole for your press rod in the middle. Like I said most of just use sockets for this purpose
