Help needed! Rockshox SID rear air valve adapter
kramonut
This is a long shot, but does anyone have one of these I could borrow??
Need it to pressurize the damper to 500psi & it's backordered everywhere. Went to two shops, but they couldn't do it. I'm in south jersey, Swedesboro area but work in Voorhees a couple times a week & can come to you to borrow it.
Thanks in advance!
I have the older one,
I seem to remember that there is some incompatibility, but if you'd like to bring your shock with you, you can try it. Or just pay for a padded mailer, or whatever. Live in Colts Neck/Keansburg, work in southern Monmouth county.
My home shock pump only goes to 275PSI, though. I think the product change was something to do with boring the tool so it's compatible with the current shocks, but I'm not sure.
Thanks so much!
I ended up finding one shop online that says they had 2 in stock...my order went thru so hopefully it ships. I have another buddy that has the red one for older SIDs...I'm trying to confirm if the red or the silver are compatible. I'll give you a shout if needed! Thanks again!
