Looking for recommendations for someone to repair or replace my rear exterior door. Location northern Ocean County.
Backstory - I have a rear exterior entry door facing north/northeast. I had the door replaced a few years ago with a Therma-Tru door and Anderson storm door. I had the door replaced because the original Therma-Tru door had water infiltrating the door frame and rotted out on the frame on the hinge side. The new Therma-Tru door and Anderson storm door is still leaking and there is water damage accumulating around the sub floor and hardwood floor on the inside of the home. I tried to seal every single thing I could find, but still there is water leaking in. I would like to have the doors repaired/reinstalled/new doors/new exterior flashing/new door pan whatever will prevent the water from entering the home. I would also like the subfloor and rotten wood replaced or repaired. If you are anyone you know has a recommendation please let me know.
Thanks,
Chris
Thanks,
Chris
