Matt_
I Get Jokes
Prepping for a new shower install so I pulled the cover off to see what type of drain I'm dealing with. I was expecting to see a castle nut of sorts but have what's pictured below. There is a key slot in the threads, but im not seeing an obvious way to disassemble. I'm guessing that's another top cover that I have to spin off next? Or is this a drain that I need to access from the bottom?
I dont mind cutting a hole in my ceiling but obviously would like to avoid that if possible. Also don't mind destroying the shower base, I need to cut it up to remove it anyway.
This is circa 2001 contractor grade stuff (new home build, not a remodel)
