Dave Taylor
Rex kwan Do
Seems dumb to waste 4oz sealant because you fixed a flat with co2.
I used a co2 tonight. Went to change tired and sealant(installed last week) was hardened on the rim tapeused co2 with stan's for years without issue, am I about to explode or something?
Running SS or gears?I used a co2 tonight. Went to change tired and sealant(installed last week) was hardened on the rim tape
Aspen problems 🤣Seems dumb to waste 4oz sealant because you fixed a flat with co2.
Aspen problems 🤣
Okay, I know you guys are joking, but we know SS is faster, so it could very likely shorten the viable lifespan of sealant.If only this were a large.
Were you in an anti-gravity chamber? How the fuck did it harden on the rim tape, and not the inside of the tire?
Because centrifugal force and or gravity.
I keep one of these in the Farley’s frame bag…. It uses propane instead of co2. It’s allegedly “ok”.
MSW XLA-40 Air Cartridge
This extra-large, 40-gram threaded air canister packs as much volume as two 20-gram cartridges with half of the weight while boosting available pack space. - Inflator operates at temperatures...www.wheelsportbikes.com
This seems like a great idea. Almost as good as using propane as a refrigerant (which it is excellent at)
How did you find this infoFrom stans site:
Is Stan's sealant compatible with CO2?
CO2 is best used in an emergency situation. If you have no other means to get your tire to seat, you can use CO2. However, we recommend that you let the CO2 out either after your ride, or after setting up your tire, and replace it with regular air. Prolonged exposure to CO2 can cause the sealant to separate and/or decrease the life of your sealant.
well, my favorite Incredibles villain is…..This seems like a great idea. Almost as good as using propane as a refrigerant (which it is excellent at)
