NJ Gator
I have 1 stubborn piston that will not retract and it is pretty far out- the pad I removed was THIN so I think it has been this way for awhile.
Tire lever method not working.
Flossed the piston with alcohol soaked string
mineral oil wiped on the piston
Removed bleed screw from the lever attached the cup and had oil in it and tried to retract piston- no luck
Removed cup with oil Thinking if the system was over bled it would need to purge oil- no luck
put OLD pads back in and used a screw driver to try and pop it back in- nope
I assume the seal might have gunk behind it but not sure how to break the caliper down...
Any suggestions? Thanks all!
