one piece crank
I have never set-up this style of tubeless rim before. Any tips on choosing tape width and/or tape application before I dig in?
Came here to say this.FattyStripper Tubeless Fat Bike Solution and SkinnyStripper Tubeless CX & DH Solution <link rel="image_src" href="http://fattystripper.com/media/FattyStripper_Logo_320.jpg" / ><link rel="image_src" href="http://fattystripper.com/media/FattyStripper_
FattyStripper and SkinnyStripper Tubeless Bike Solutionswww.fattystripper.com
These have been great on my similar FatBoy rims.
New pre-built rims, set up tubeless but bad tape job. I can see sealant leaching through voids in the tape, so I figured I’m better off removing the tape doing it myself - peace of mind.
I guess I need tape a little wider than the fabric?
Don't you need to change them each time you change tires?FattyStripper Tubeless Fat Bike Solution and SkinnyStripper Tubeless CX & DH Solution <link rel="image_src" href="http://fattystripper.com/media/FattyStripper_Logo_320.jpg" / ><link rel="image_src" href="http://fattystripper.com/media/FattyStripper_
I've used Fatty strippers on 2 sets of tires. Never burped once. The best Jerry, the bestFattyStripper Tubeless Fat Bike Solution and SkinnyStripper Tubeless CX & DH Solution <link rel="image_src" href="http://fattystripper.com/media/FattyStripper_Logo_320.jpg" / ><link rel="image_src" href="http://fattystripper.com/media/FattyStripper_
Yup, they seal to the tires themselves when installedDon't you need to change them each time you change tires?
My new Rhyolite wheels have a 90mm rim width, 84mm internal width. The rubber/fabric rim strip is 75mm wide and came taped with 80mm tape that had leaks all over the place (only ~2mm of possible adhesion on each side of the rim strip, if centered, which it wasn't).
I'm thinking of cutting the rim strip down to match a 65mm-wide lip, leaving 10mm rim strip coverage on each side of the 44mm-wide rim holes. Then use 78mm tape, with 6.5mm of tape adhesion on each side of the rim strip.
Man do I hate rims with holes in them. Are there any 90-100mm hole-less, non-carbon fat bike rims?
I only own non-drilled tubeless fat rims - Specialized Stout and Bontrager Jackalope. They are a dream to set-up and require zero tape. I'm going to set these new rims up proper, and tweaking the rim strip and tape widths should be right on the money.I maybe going against the flow here, I use the ‘ghetto’ fattystrip on both my 26” and 27.5” fat rims, both alloy and both with holes. No issues (other than initially figuring out the right pressure). Rims are tubeless but I actually like the idea of the strip stiking to the tire. I bought a bunch in case I need to replace it (will need shortly as I will replace the 26” wheels). Personal preference I guess. Only negative is having to trim the strip once you mount the tires. I’m also working on recycling the used strip but that seems a little bit of a …stretch!
