Dave Taylor
Rex kwan Do
Well guys, I’ve had a good run on the Maxxis Aspens. I have used them for everything from training rides at Hartshorn and Huber to podium at several NUE races. I used them in the marathon nationals for two years and tons of rides and Ringwood and the Frederick water shed. I’ve also chimney rock for years without major issue. I’m not sure if Max has changed the compounds or what but I still use the same 2.4 mm tires and even with a rear insert now. I’ve tried all different sealants, and for some reason this year I have had more flats than ever before. Not just pinch flats, last night I had a pinch and a tread flat at the same time. I always use exo tr version.
That was the long of it. The short end of it is I need a decently fast, high volume, XC race tire that’s a bit more adorable. Maybe it’s just a string of bad luck, but I’m not liking it. Let me know what you got.
