What's that, carbon paste?Forgot to fiber grip the dropouts when I swapped back to gears and it was making a creak, creak, creak noise. Fuck that. Fixed. I also redid my headset because it was probably time.
Would it make sense to use it on steel frame? Aren't those microbeads supposed to bite into the surface to prevent slippage?Yes.
Interesting... I'll have to apply some to the drop-outs on my Chameleon. Haven't heard creaking yet, but of course I haven't ridden it yet. 🙁I use it on any slidey dropout. Doesn't matter how tight you make the bolts, the dropouts move against the frame as you torque the rear wheel.
I see my old Haro hanging in the background !Did a couple things today
Washed it
installed a new stem.
cleaned the cranks and BB
Cleaned the DT Swiss hub and re-lubed the ratchets
Installed a chain guide on the POS
Yes sir!I see my old Haro hanging in the background !
May have to try that on my IF with Paragon RockersI use it on any slidey dropout. Doesn't matter how tight you make the bolts, the dropouts move against the frame as you torque the rear wheel.
come ride that fat bike in edison this week! i'll be out snowshoe grooming tomorrow!It's snowing so it's fat bike o'clock. I took my newer Rainbow cassette and chain and put them on Pinky with AXS2.0 the other day, or week so I put my less rainbow cassette on with a GX chain. Seriously? GX. There's a rainbow shortage even for me.
I also apparently only have one AXS shifter somehow with like 6 groups. I must have a bag somewhere with the rest. Luckily I have a bunch of LH matchmakers because I run my shifter backwards.
I made a little chain protection thing out of a water bottle because I'm running a narrower q-factor than stock and my chain rubs the frame.
And someone gave me this cap as a tip. It's dope.
CT was NG - too much icy crunchy stuff today but the bike rides so nice. and that uphill to Schooleys on the trail is WAAAYY above my skill level.if doing columbia trail, take it up schooleys mountain park extension - cause mtb!
have fun - looks good!
It took me forever to get the shifter comfy. The AXS shifter really doesn’t work good with XTR brakes. I tried a matchmaker but it didn’t clear right. I ended up with that same SRAM matchmaker x.
I got the updated rocker panel and the bolt to tighten the brake clamp barely clears the shifter.Does the Stroke Servo thing on the XTR brake hit the shifter?
