a.s.
Mr. Chainring
Purple housing!Finally built up my white industry hubs
Also thompson stem installed been digging polished silver lately 🤘
Pedals and headset also 🤘Purple housing!![]()
yessss! more purple! Take note @Dusty the Whale !
Which ultrasonic cleaner do you have? It does seem like a great way to clean cassettes. I would not clean an old chain, though - just install a new one.Ultra sonic cleaned my drive train , bled my brakes , and replaced my brake padsView attachment 151353View attachment 151354View attachment 151355View attachment 151356
I just have a cheapo one from harbor freight. 85 bucks without any coupons but you can always find a 20 percent off one online. I put the chain in By itself and ran it through 3 cycles . The water was absolutely gross and I emptied it between the second and third cycle but it got out all the gunk in the crevices and moves completely freely. That's the solution I use works great and won't harm the metalWhich ultrasonic cleaner do you have? It does seem like a great way to clean cassettes. I would not clean an old chain, though - just install a new one.
Same here, but used diluted Pedro's Pig Juice because...it's not Simple Green, I guess? What dilution % did you use? I'm willing to give it a try since I have a jug of the same cleaner in the garage and plenty of spare chains...I just have a cheapo one from harbor freight. 85 bucks without any coupons but you can always find a 20 percent off one online. I put the chain in By itself and ran it through 3 cycles . The water was absolutely gross and I emptied it between the second and third cycle but it got out all the gunk in the crevices and moves completely freely. That's the solution I use works great and won't harm the metal View attachment 151447View attachment 151448View attachment 151449
Well I would be lying if I gave you a correct % I just put a splash in And if after a cycle it's not doing a good enough job add allitle more. Ive done a whole bunch of stuff with it in the past and I still havent used much of the bottle. This is the second time I've ran that chain and cassette through it. The biggest section of the cassette doesn't fully submerge so you do have to turn it. As for the chain I wipe it with a paper towel between each cycle to get off some of the excess grime that the ultrasonic cleaner worked out of the crevices.Same here, but used diluted Pedro's Pig Juice because...it's not Simple Green, I guess? What dilution % did you use? I'm willing to give it a try since I have a jug of the same cleaner in the garage and plenty of spare chains...
I did two chains (separately) and the amount of crap that came out was unbelievable. Still, after at least 3 cycles and wiping them after each cycle, I lay them on a strip of plastic with the side plates vertical and applied chain wax liberally (I had a free sample of that stuff), which brought out more crap. The chains do spin better than new though (or so I think).Well I would be lying if I gave you a correct % I just put a splash in And if after a cycle it's not doing a good enough job add allitle more. Ive done a whole bunch of stuff with it in the past and I still havent used much of the bottle. This is the second time I've ran that chain and cassette through it. The biggest section of the cassette doesn't fully submerge so you do have to turn it. As for the chain I wipe it with a paper towel between each cycle to get off some of the excess grime that the ultrasonic cleaner worked out of the crevices.
I've read putting items to be cleaned in a glass jar or a zip lock bag with simple green in the jar/bag, allows you to keep the water clean. Plastic zip lock bags do dampen the frequency a little bit. Glass (pickle) jar is the way to go.
Think along the lines of a sous vide.
Its been on my list of things to add to the garage since I'm always working on stuff, just haven't gotten there yet.
I did some research on that (1.5 minutes on google qualifies as such) and you can get a 10L unit for $125, the actual tank is 12"x9"...I think that is next in line, I hate scrubbing on those massive cassettes and especially putting them back together.I've used a glass jar with mine and it works well, especially for smaller parts where you might not want to fill the entire thing with solvent.
I also have the HF one and I'm always tempted to buy one of the slightly larger/more commercial looking ones. I'd like something large enough to fit a cassette fully as well as allowing for a longer timer setting.
I take the cassette off directly on to a long zip tie. Keeping the loop very loose and drop the whole thing into the ultrasound cleaner..... after a dunk n shake in mineral spirits that is. let’s me get everything clean w/out futzing with putting the pieces back together.I did some research on that (1.5 minutes on google qualifies as such) and you can get a 10L unit for $125, the actual tank is 12"x9"...I think that is next in line, I hate scrubbing on those massive cassettes and especially putting them back together.
