Oh noes - how do I find the valve - it's invisible!
Finally got the cranks and BB installed, but now I ran into a new problem. The bashguard I have from Wolf Tooth doesn't play nice with the XTR crankarm. It's keyed correctly, but it doesn't lay flat, so now I'm slumming it with no bashguard and a SLX spider/chainring. New pedals are sexaysexay.
Do you really need the bashguard? Does that XTR crankset use the 104BCD?
Do you really need the bashguard? Is that XTR crankset uses the 104BCD?
Afaik, wolftooth doesn't make a non-bash Shimano mount. Kinda dumb, but not enough for me to do anything/complain about it.
The SLX/XT rings wear like iron (cause they are 😉), and the XTR is super tough from the cold forging, so it's not like the aftermarket stuff is necessary...even if the mounting system is slick.
