Mr.Moto
Yeah, especially when the bladder is not working! Luckily youtube prepared me for the removal.Those tanks weigh a quite a bit when filled with water!
Now you can come down and show me how it's done.Last winter the furnace cut out. Knew it was likely the thermocouple. Had PSE&G come look at it just in case. Guy that came was super cool. Swapped out the thermocouple and did a quick once over and cleaning. Gave me tips about a couple of things that should be taken care of. Said the expansion tank needed replacing, which it did. So decided to give it a go before cold weather really hits. After some you-tubing and research and about $60 for the tank, things are back in business. All the zones were in dire need of a purging. Now all zones and furnace are nice and quiet. Should have done a purge long ago.View attachment 225537
This is my 30yo compressor - which stopped compressing.
Can't be too tough, so i pulled the cowling off (T20s, the guy on the internet used a jigsaw..)
Pulled the head, and the filler tube.
Rebuild kit not available on searspartsdirect, so looked on amazon.
$15 and it is overnighted. New cylinder sleeve, piston seal, and o-ring.
Sleeve drops in, Piston seal is held in by a simple cap, screwed down to the piston rod (there is no piston pin)
couple of reed valves in the head do the work.
$15 and about an hour to take apart, put back together - fills up fast!
now to find some filter material for the intake.
If you ever see an old sears/craftsman compressor being tossed - grab it.
Easy fix. Hopefully i don't die from diy.
As someone who systematically takes things apart just to know how they work I could not disagree more! To each their own I guess. I'm not always capable to put things back together the way they were, I'll give you that.Rational alternative - buy new one and don't worry about it for 10 years. Plus don't waste several hours!
Also, that compressor is probably going to be good for another 10 years anyway. Or be in the garbage tomorrow.
I also wonder if compressor construction quality and reliability has gone the way of many appliances, where their life expectancy seriously decreased over time.
Please Google "air compressor exploded" and see videos of them less than 15 years old letting go due to rust.As someone who systematically takes things apart just to know how they work I could not disagree more! To each their own I guess. I'm not always capable to put things back together the way they were, I'll give you that.
Spoken like a true "moneyed man".I look at it this way. Time is fixed - you only have so much. You can't buy more. A compressor is a tool. Why waste time futzing with a piece of crap old tool when you can buy a new one and spend the time actually using said tool?
Why use a new tool, that's a waste of time. Just pay someone else to do it.I look at it this way. Time is fixed - you only have so much. You can't buy more. A compressor is a tool. Why waste time futzing with a piece of crap old tool when you can buy a new one and spend the time actually using said tool?
It can happen to a much newer one. The issue is condensation inside the tank not being drained while the compressor sits unused. If not mantained properly, a new, cheaper and thinner walled compressor may last even less. Thinking of tools like something that can sit in a garage for years not being used and then just be ready to be used in a jiffy is not always true, mostly an idea entertained by who doesn’t use tools.Please Google "air compressor exploded" and see videos of them less than 15 years old letting go due to rust.
@Patrick buy a new one.
Do you have a duct or some other mechanical function where they are pecking? In my place, they peck in a spot where we have a high mount heat vent as they hear a sound and think it's a bug. I hung some CDs in a tree nearby to deter them which worked till the CDs fell off the tree.borrowed the neighbors extension ladder for the weekend, some of the boards under the dormer eves were peeling back and birds were nesting in there.
apparently the woodpeckers like 100+year old wood as well whodathunk?
You're right. I do tend to play things safer than needed. I've also had pin holes in old compressors, didn't blow up but I got rid of them anyway.how much time would it take for me to buy a new compressor?
It has to be running the next day to match what i did in two hours (max)
mostly cause i had to watch the guy jigsaw the cowl cause he didn't have a T20 long enough to fit. couldn't look away.
i don't subscribe to anecdotal videos of exploding things - cause people explode them on purpose.
it is also more likely that rust will create pinholes - amhik.
I have one in the same vintage. No issue on the compressor, but the I need to tap the top of the contactor every now and again to get it to start the first time. One day I'll pull it apart when my fist is no longer strong enough to give it a bump. Nice save @PatrickThis is my 30yo compressor - which stopped compressing.
When was it painted last - 10 yrs ago?
