pkovo
Picked up a boost spaced frame on deep discount which I am budget building using parts I have on hand.  Planning to use a set of shimano deore non-boost cranks with a nonboost RF 4 bolt ring.  This frame has a 73mm threaded bb shell.  Im
Installing a Shimano mt501 BB designed for 68 or 73 bb shell. My question is:
If I need to space the cranks/chainring out a bit, can I just use the extra bb spacers that would typically only be used if my bb shell was 68mm? Any issues with doing that?
I imagine the spacing may end up too wide for that plastic tube between the bb cups to seal properly, but if thats my only concern, I can live with that.
Guessing I might not even need to use spacers to get this to work, but I’m starting out with a 2.6” rear tire on plus rim and want the ability to potentially step up to 2.8 or even 3” tire down the road so I may need extra chain clearance. Thx!
