Hartshorne/Huber Conditions
Also a log down on the GT connector where it meets questa ridge. i cleared debris and moved it over a little but prob needs to be cut
Looking for pointers on where to park to start the loop, is there a map that I can get hold of before hand to map out the loop. I looked at the Wiki section which I thought had maps, etc. but no longer seeing them.
I found this - https://njtrails.org/trail/hartshorne-woods/
Thank You
2 GPX files for Hartshorne and Huber Hartshorne. Some of my preferred ways of riding there. Park at claypit lot.
Thank You
The map can be found here.
This is the loop I like, see map below. If you park at Claypit lot you follow the red line out. This includes a stop at the light house which is not on the map, but the red line will get you there. The blue line is return.
You should use Trailforks app to check out new places. It's easier to follow.
