Couple down. First is halfway up hally
Second was on white just past the fuzzy intersection
Here's some shots of the beaver pond bridge over at the "Land of the lost" when it was installed, courtesy of AllamuchyJoe. I don't think there's a permanent solution to eliminate the beaver dam without dynamite or heavy machinery. Raising the height of the bridge is the way to go. Would require a work crew to drag materials in, build the higher support structure, and lift it. And whack together some approach/exit ramps.
Count me in if you need a helper to tackle this.
Willing to lend a hand as well. At least there’s nearby access off Lozier road or old Waterloo road to bring in materials.
Does the bridge need to be lengthened? It's hard to tell in the picture, but it looks like the lead into the bridge may also be under water? Add rocks?
