Would be cool if they made a frame that would take a modern groupset, $560 for that would be sick.
Holly triple triangle BatmanMaking progress on this build.
Re-laced the front wheel with black nipples so the wheelset would match. Using round spokes in the rear but you can’t tell…
Tried 2 different fork options to see which way the bike fits better. First is internal so the front end is steeper.
Second will run an external lower and bump the front out like a degree. And it looks cooler so…#2. I just have to order the headset.
Also waiting for a rear caliper so this will be a next week project. I also want to order matte black Zipp stickers for the 404s.
Would you be interested in this?I seent it and immediately said, yes.
i see your mom stopped by and took all the big nuts before he woke up.
Poor thingWould you be interested in this?
Yes, and apparently you're also a beekeeper...that part resonated with me way more than the guitar talk as it's a family business that I couldn't keep going since I moved over here.I talk a lot.
I have a neighbor that started beekeeping. Then he started making mead. Now he's in the process of trying to open a mead distillery a bit north of you.Yes, and apparently you're also a beekeeper...that part resonated with me way more than the guitar talk as it's a family business that I couldn't keep going since I moved over here.
Had to look it up. I thought that was a nono though, according to @Steve Vai in that interview mixing honey with water can result in botulism...I have a neighbor that started beekeeping. Then he started making mead. Now he's in the process of trying to open a mead distillery a bit north of you.
