chainsawer
Today I dropped into Stephens to catch up with all known issues. See red waypoints. This included removal of the massive double header leaner that finally came down on “Upper Woods Road”. Removal of shoulder level hazards on “Border Trail”, and the removal of a blockage on a very little used trail near “Swamp & Chop”. Then I repositioned to Firetower Road to get an “on the ground” blockage at the “Unblazed/Campfire trail” intersection out near the Gravity Cavity area. Finally from Continental Drive, hit a few on the Morris Canal Greenway, where it comes within view of Rt 80. The targeted vertical leaner was super hazardous to work on so I couldn’t fully clear it without killing myself. With the aid of a rope, I was only able to step it back away from the trail to open up a wide passage around it. Was lucky enough to get that far. To finish that would need a come-a-long, or a little time to let mother nature and gravity do her thing
While we’re talking about the Morris Canal greenway, the section I traversed was very ripe for some sweeps with the brushhog. Very overgrown. Getting the brushhog there might be a trick…maybe better for a Stihl pole trimmer or a weedwhacker with the metal blade?? You can probably access easy enough from Continental drive, but there’s a very steep punchy climb just as you get to the stretch that parallels Rt 80. Coming in from the Tilcon lake side (under the Rt 80 overpass) would suck because that’s rocky AF. See last 2 pics for sense of the greenway trail overgrowth...
