one piece crank
1pc Cranky
Garages are for doing cool $Hyte, regardless of size 🙂
seems like it but at least they took care of it.Few extra ugga duggas really sent it a little to hard.
seems like it but at least they "took care of it".
I bet they chucked the plastic box the terminal was wrapped in...would fit what transpires being their work ethic.Back in June I had my alternator fail and it ruined the battery so they both got replaced at the local repair shop.
Yesterday afternoon I went to move my car after unloading some stuff in the driveway and when I pressed the button to start the entire dash went dark and the car had no power.
Went under the hood thinking the battery maybe was faulty and found this.
The little cinch bolt that holds the terminal on broke off. So the terminal was just sitting there and it was loose enough to not make contact. My assumption is they overtightened it when they put in the new battery.
I moved it over to make contact and drove it over a few minutes away to the shop. They took it right in and he kinda mccgyvered it but didn’t charge me anything.
While I’d prefer the OEM replacement this is functional enough for me. And the price was right.
The only mechanics I trusted to work on my vehicles have sadly passed away. Maybe I should look at the 4-post lift…These kids in some of these shops need to have their battery impact guns taken away permanently.
I don’t disagree it was kinda klugey repair but the car is from 2013 has almost 100K miles on it and I just need it to last me until next spring so I can replace it.
had the car since 2016 and 36K miles as a CPO. Spent a lot of time working at home and then COVID so it hasnt been used as much, but its had way too many issues for the low miles it has (thankfully most covered under the CPO warranty before it expired).Damn wish I could drive that little right now
just biding my time hoping in the spring i can get something a little more up to date even if I will have to do tires and brakes before the winter.
Turns out it was the sway-bar links making the clunking noise as they wear out. That also only cost me $675! Winning.
I just dont have the tools, skill or time for these kinds of repairs any more. I know the parts werent that expensive but it is what it is these days.
Too late now, but I recently did the sway bar links on my Suburban in less than an hour. Parts were $20 on Amazon.
the only reason i was "happy" with paying $675 back then was because the original diagnosis from the local repair shop was a bad steering rack and $2300.Not sure I'd want to pay $675,
