Using tubes not sealanttry it and see if it seals bro
From what I have read this is a no no. I really don't think this should ever be tried on a road tire at the pressure and speed it is not worth your safety.
Maybe I misunderstood or misread. I thought he was saying running a tubless tire on a non-tubless rim without a tube.In what way? He wants to run non tubeless tires on tubeless rims with a tube in the tire. Not seeing how this would be any more dangerous than any other tubed tire setup.
The big difference for tubeless stuff is the bead tolerances fits are tighter bc they need to hold pressure nothing really structurally different here
Other way around, non tubeless tires with tubeless rimMaybe I misunderstood or misread. I thought he was saying running a tubless tire on a non-tubless rim without a tube.
I should check, they are non tubeless Vittoria tires on 10 yo sram tubeless carbon rims.Is the tubeless rim a hookless bead? IMO that would be the biggest factor. I have no way to confirm, but I assume all tubed tires are designed for a hook bead rim.
On my road bike I have tubless ready rims but I choose to ride continental 4- season tires with tubes no flats this summer.Other way around, non tubeless tires with tubeless rim
I am not an engineer, but I think you are running a PSI of 90 to 100 so the tire seats better. I have ridden with have the tubless rims and tires running 65 to 80 PSI.If it wasn't safe, how could you ever put a tube in if you got a puncture?
