I've been pulling the power steering pump on my daughter's 2015 SLK250 for about 10 days now. 🙂 I stare at it, curse a little, stare at it some more. The engine bay can hold a 5.5L V8 but somehow a 1.8L 4 fills the entire space. My hand is all cut up from loosening the air pipe to the turbocharger. I've probably done about 30 minutes of actual work
I was happy to find a bootleg manual on Etsy that was obviously meant to be navigated with software. It's over 11,000 pages long and takes a lot of searching but it's still very nice to have. I can only see 1 of the 3 bolts that hold the pump. Sigh... Despite the length, surprisingly annoying tasks like removing the intake pipe are just "disconnect air pipe from turbocharger".
That reminds me that I need to order 1/4" ratchet extensions in 30 different lengths.
Can't believe she's driving already! Convertible? When I turned 17, my dad gave me a '66 Mercury Monterey that he got for free from some guy at work...
Not quite yet! She doesn't even have a permit even though she's old enough. Kids...
It's a '15 that we picked up from my dad in FL late last summer and road tripped home.
My parents gave me a 1984 Chevy Celebrity when I graduated college.
So.... Today I spent some time cleaning the hell out of everything, put some parts back on, then I started up the car and moved the steering wheel back and forth. To my great embarassement, it looks like a $5 o-ring responsible for the leak. Dumbass. I had convinced myself that it was OK.
Well, this thing continues to piss me off on my daughter's SLK250. I replaced the o-ring and it still leaks. As soon as I start the car, it starts seeping. The manual helpfully suggests "replace o-ring" whenever you pull the line. I'm beginning to wonder if there's another o-ring that gets inserted into the pump first. The manual and all the various diagrams on parts resellers are not clear.
I don't see anything wrong with the fitting or the bore where it fits. I do have a new pump but I'm having a hard time seeing what would be different. Maybe I'll order the hose as a hail mary.
Is there a high pressure bypass ?
Just guessing...
Just guessing...
I have no idea. Are you thinking that maybe something failed?
I found someone on zuckerbook with the exact problem last spring but no follow-up and I have to be approved to post to the group, which is a 50/50 proposition in my experience. Fingers crossed.
Seems strange to just blow by the rings, unless your idea of one more way up front missing?
Poking at ideas here.
RIP Car Forums.
I'm starting to think maybe a crack in the fitting. I don't see anything, of course, but it wouldn't take much.
The MB parts pictures are maddening for the PS system. There are two part numbers for - apparently - the same part. One is labeled "high-pressure line" and costs $300. The other is an "expansion hose" with a slightly different part number and is $200.
Got an old Autel TS508 TPMS tool, to program MX sensors and replace the factory ones. The vehicle will not recognize new tire position after rotation without a dealer reset! Now I can clone and recode the sensors for 5-tire rotations.
@UtahJoe in that video the guy uses an air chisel, did you try that first before resorting to a sledge? Just wondering if it's worth trying or not.
i always buy a brand name when i do wheel bearings (or anything else critical and potentially challenging to change) buy one with a good quality or end up doing the job twice in short order, i figure my time is worth way more than the price difference.
in this case moog or timken would be appropriate, i put SKF bearings on my truck last fall.
This, OEM is a consideration for these kinds of jobs...
