For Sale Pay It Forward - Computer gen3/gen4 Equipment - Free
dvaidya
I have some gen3/4/5 computers (tiny/slim Lenovo/HP) with decent amount of memory (>=8gb memory (mostly 16gb), >=256GB SSD drives in them) that I was running Windows 10 on hooked up to TV/Audio equipment. They were running Win10 just fine but with MS no longer supporting and patching Win10 I have moved to gen10/11/12 setup so the older systems are available in case someone wants a simple browsing system. I can install Linux Desktop on them which works without any issues.
Computers are i5 I believe. I also have unused wired keyboard and at least one monitor 1920x1080 (Dell/Asus) monitor.
Located in South Brunswick / Princeton area.
Could be good for someone needing a Zwift setup on the cheap. I run mine off a 12 y/o macbook and it runs well enough.
Can you provide the CPU model#? My 7-8 yo laptop is a bit slow loading Zwift. How is zwift on Chrome?
yikes - Android apps run in a container and have a horrible time with BTLE devices.
While I haven't tried it, my prediction would be "not great" if at all.
I'm going to try it on my chromebook
If you are an apple person, 1st Gen Apple TV 4k is a good choice. just because it works nicely with the companion app on the same platform,
along with remote on phone.
It installed, and started. Seems to talk to the companion app. I have an Acer Chromebook 314.
I can install either KUbuntu or your choice of Linux OS or Chrome Flex which I still need to attempt to install on the system or leave the disk blank for you to install your choice of OS.
HP Prodesk 600 G1 - i5-4590t, 16gb RAM, 256gb SSD drive (Samsung 840 Evo), WiFi, KUbuntu Linux as Os
Lenovo ThinkCentre Tiny M73 - i3-4130t, 16gb RAM, 500 gb ssd drive (Samsung 860 Evo), WiFi
Lenovo ThinkCentre MT - i5-3570, 20gb RAM, 500gb SSD drive ( Samsung 860 Evo) (Successfully installed Chrome Flex)
Dell Monitor 1080p 16:9 (it’s either 19 or 21”) with cable which works with all 3 computers
I am going to attempt to install Win11 Home on the systems. If I am able to install it I will leave it in non-activated state and based on the research so far you could potentially continue to use it but some functionality might be restricted and patching.
im out, my software (sadly) doesnt run on linux.
So I was able to install Windows 11 Home on the ThinkCentre MT desktop. Not sure how much nagging it will do after 30 days of not activating but you are more than welcome to have that and I will include the Windows 11 install on a bootable USB.
Ive been ruuning 11 for a few months. No nagging except for the message in the lower right hand corner.
I had to jimmy my registry to get 11 to load to bypass a hardware check in the installation.
Do you have full functionality especially all the Windows patches being installed?
