I though my dad was the only one who drank Busch lightMade my harbor freight porta-band not so portable and into a mini band saw. Welded up a stand based on a few YouTube videos I saw.
I did, Greg was really nice and did a great job.@serviceguy did you wind up using gr tech for the asbestos removal?
breaker bar on the spark plug, once it moves a little, work it back-n-forth to get it out (thank you @extremedave ) - it is just stuck from overheating.
if it is cross threaded, you'll need a new bike. you can put more leverage with a breaker bar than a gun. use a spark plug specific socket too.
squirt some thread-release crap in there so it sits while you are away..
so the pcv valve broke while doing this? isn't the valve on the crankcase side of the system? (so if there is a tab anywhere, it is in the crankcase, not in the intake) -
if it is the other way, someone needs to have a little defensive-engineering talk with the new guy....
I do need a new bike! I mean an actually functioning bike that is.
This is the PCV pipe (I guess the check valve is integrated). The connector that broke off is the one in the lower left corner, as you can see there's 4 small tabs that are supposed to click in pace on top of what I thought was the intake manifold but it must be the top of the rear head, what was i thinking! The new guy has probably gone already...I am hoping that the two missing tabs got stuck on the hole somehow so that i would be able to pull them out...getting back at it with a air ratchet, the space is so small (even after removing a bunch of parts) that I could not apply any real pressure on the ratchet. The breaker bar was working but I have about 10 degrees of rotation to deal with, both my el cheapo craftsman ratchet as well as the top of the line HF composite (fancy) ratchet only click once on the backstroke.
Thanks, they were on my radar. Lately I've been concentrated more on construction tool, this is a unexpected (and really not welcome) detour from my schedule...I am actually looking into the 120t / 3° newer ratchets (SK but also Craftsman, as new-ish permanent resident COO is important to me). I may actually fetch some USAG when I go to Italy in May..WERA ratchets are about $30-40-ish from a few stateside dealers, full metal head, with 5° engagement. Totally worth it if you use them with any regularity. Search for Zyklop, you'll find them (not the swivelling head, though those are good for other things).
Yep, I did remove both the coil and the coil bracket (the latter making the biggest difference) with allows the harness to get out of the way but requires the coolant bypass pipe to be loosened. It just a weird location, ended up laying on top of the engine and I have the bruises to prove it...just pure fun!
Anyone know where I can find a bathroom sink and cabinet which is 35" wide?
Fit in, okay with 34" and build out. 32" or 30" don't look right. Just want to avoid shaving into the walls to fit. Houses with formica cabinets suck, so much is custom and not to standard. Considering custom to make it look rightfree standing, or fit into a space?
can buy a 36", and have at it. if fitting a side to the wall.
easy enough to cut a top to fit.
