OOS MOGA
Get to work !
I just got back from work!
Whats your estimated time of completion? When are we going to see this beast and which park will its first ride be? I suspect your home park RW?
I’ll have to work on it on Saturday, but again I may not be able to sleep and putting it together tonight! Oh, decisions, decisions. It looks absolutely tiny, so much gor me being afraid I should have ordered a medium.
In orthodox serviceguy’s style there had to be a glitch (more than a month delay wasn’t good enough). FedEx delivered the box open and upside down (probably because the bottom had been open, presumably by customs). Checking with Knolly if anything is missing. Other than that it’s awesome, not sure I want abuse it on the trail! J/K
And yeah, I think some recon around the house is long overdue so RW it is.
At least try to get the shock, BB and HS in tonight. Last frame I bought without a shock took close to a month with tech support to figure out the bushings.
What type of crank? I have an older set of cranks with BB if you want them. Was planning to send them off. Square or spline varieties
This pos. I don’t know much about bikes or parts. I’m fine working on them but I can’t tell you specific about something.
Big thanks to @jklett and his pal Jordan (was that his name? I cant remember if that's right) for coming down to Harts and putting up with my mechanicals and shitty climbing. The light drizzle was really nice though. @Paul H you'll be happy to know my dork disc is gone. It broke and was loose knocking into shit and took us like 10 minutes to try and break off on the side of the trail. 3 minutes later, my chain went into the wheel and I (jklett actually did the work) had to reset my limit screw. Thankfully that all happened near the beginning and the rest was fun! Now hopefully my shit works...until I try and fix it again and make it worse.
I should have a spare crank and BB for that
Only variable is the BB spindle width which is hard to guess. If you can get the cranks off and measure, i can check my parts bin
you owe Jason a beer we we're down in two weeks
btw, I can only ride on May 4th, Saturday. have the Komen 5K on Sunday
Please replace the dork disk
