You. Need to go buy ivy dry. Right now! And then soak that in it until it dries out. 3 or 4 days max
Yes I got some on my face requesting name change for Harvey Dent
@Paul H has a pick WC fallOn second thought. It's on the face go get a prescription and save the ivy dry for next time.
Also how'd you manage that?
Nice! Unfortunately Two Face is taken.....
heal up - get the prednisone if it gets worse......
That will buff out
we'll see what happens face leg waist stomach and are have it arm and leg are the worst and it burns like a flesh burn
Yikes. You should have taken a shower when you got home.
Actually, there's a discussion around here about that. You should have taken a shower (not a hot shower) and wipe your skin thoroughly with a wash cloth and soapy water, that would have removed the oil that deposited on your skin 'before' it became active.i did sadly i was already screwed
Yea use dish soap after you think you might have been in poison ivy. It will break down all the oils unlike the soap we are supposed to use.Actually, there's a discussion around here about that. You should have taken a shower (not a hot shower) and wipe your skin thoroughly with a wash cloth and soapy water, that would have removed the oil that deposited on your skin 'before' it became active.
Since I became aware of this video, haven't had anything significant, just a small spot here and there.Actually, there's a discussion around here about that. You should have taken a shower (not a hot shower) and wipe your skin thoroughly with a wash cloth and soapy water, that would have removed the oil that deposited on your skin 'before' it became active.
I always take cold showers I was told hot I'm going to the dr over this Its on fucking fire like a chem burn
just go to any urgent care/redi med kind of place. that looks incredibly bad, prednisone will definitely help, but that is going to take a while to clear up, it will take forever if you don't get the steroid! good luck, I hate that shit.this is the right answer for it, probably get a shot and be significantly cleared up in 24 hours.
cold showers after contact with PI, it closes your pores so your skin doesnt absorb the oils as fast. A hot shower opens the pores and lets the oil in and makes the reaction happen faster. Then use dish soap ('brown' soap, bar laundary soap works too, as does my wifes stupidly expensive facial wash/makeup remover) to clean it off. Buy a bottle of that ivyx i linked and start using that, its the closest thing i can find to the ivy block i used when i was a kid/teenager camping with the scouts and it worked back then, so far so good on this new stuff.
