jumpa
I was also interested in the weight difference between the two wheelsets. Also what pressure are you running in the 3.0s?
I would probably say the weight difference is a wash, but I'll try to head to Jim's shop to weigh both wheelsets this week. Pressures were about 15lbs front and about 18lbs back, @jimvreeland literally set the wheelset up tubless an hour before the test ride so I didn't want to risk burping by dropping it any lower, but I will play around with pressures on the next rideI was also interested in the weight difference between the two wheelsets. Also what pressure are you running in the 3.0s?
That looks like an awesome bike, I've been eyeing the horsethief and the stumpjumper 6fattie, both look dope!Thanks. I would think you could go significantly lower. I run 15 now on my 29er. I'm getting a horsethief in a few months and also get a 27.5+ 3" wheelset so interested in your observations
