Mathers
Like a good old patch? I was wondering if that would hold.Glue on tube patch from the inside.
I've done it, as long as you get the area really clean and it's not a slice it works great. Even with a slice it'll still work if you stitch it first to hold it together.Like a good old patch? I was wondering if that would hold.
Looks good 😎Did the debut ride of this tonight. 2021 Giant Trance X 3.
Sweet bike..handles well, and climbs well too, I was able to make the common climbs at Allaire with much more ease.
Full suspension is awesome. Tires are meaty, grippy, and kick up a lot of dirt lol...will probably get a front fender.
Love the slack head tube angle, much more upright seating position. Very comfortable.
Will probably go with a little less pressure in the fork.
View attachment 137334View attachment 137335View attachment 137336
Thanks! Yeah, love the simple color scheme. Nice clean lookLooks good 😎
Push on with the correct tool.Question
Decided to replace my headset but the crown race is different isn’t split will this just push on or do I need a tool? I just don’t want to get it stuck.
Which could be a PVC pipe that properly fits it.
Youtube has tons of videos.
Yes, push. With a hammer.
Don't worry, the earth still make a great hammer.What happened to the old method of upside down fork and slamming the whole thing into a hard surface?
The sealant monster.
monster.
Re-weigh the bike, with a stanimal that big I bet it's at least 2 lbs lighter.While riding with @Mare45 at RV on Wednesday - the rear tire on the fatbike started to loose air.
I didn't think much of it, figured i'd picked up a thorn, and it would seal.
Fast forward to yesterday's ride with @mattybfat and @soundz.
The tire is soft coming off the rack, so i pump it up - we are chatting while getting ready
and by the time we are ready to roll, the tire is soft again, not flat, just soft.
So pump it up again, and listen closely. There is a small leak in the sidewall (actually two)
so I shake the rim to get the sealant over there, and none is coming out.
Give the rim a shake, and i can hear it sloshing. Matt mentions that it sounds kinda thin.
We dart the hole, it doesn't seal by itself (darts react with the sealant)
Fart around some more - head out and repump tire every 25 minutes.
So i pull the tire off today, and the stans is mostly dry - still glistening, but not running.
Shake the rim - and there is water trapped in the rim cavity. Probably the result of
crossing the concrete bridge at 6MR after one of those rain storms (during a tm session w the Jasons)
Anyway, pull the valve stem, and shake the water out. Just like sunburn, start peeling the sealant
and i can't stop - interesting to see all the things that are stuck in your tire - which is why the emergency tube
goes flat.
Proper inside of dart. Had to make the hole large enough to dart it too.
All set.
