235/40r18 ft 275/40r18 rrPlease don't put Potenza's on that thing. What size tires are you looking for?
I was never a big Firestone fan, but when I was looking for new summer tires for the boy's GTI the Firehawk Indy 500s got pretty good reviews. They are great tires, quiet, good ride and reasonably priced. Also the tread pattern looks pretty cool/aggressive which was a selling point for him. 😎235/40r18 ft 275/40r18 rr
^ This.
Sounds good @qclabrat
@Dingo holley carb jet fit like a glove... Rocker stud goes in that hole next to it and traps it
Then I put my oil primer in and spun it up to make sure it wouldn't move.... Now onto the other side
The main problem is the oil does not return to the pan fast enough. It stays "upstairs" in the heads and lifter valley. Adding a high volume/pressure pump just adds to the problem. Builders will coat the insides with glyptal paint smooth the casting surface, restrict flow to lifters or rockers all to aid keeping the oil in the pan to feed the crank bearings. Dry sumps are for another oiling problem...They must make an oversized pan ?? is that off the table at this point?
(probably not necessary after adding HV oil pump then putting in a restrictor?)
do you have an oil cooler separate from the one in the radiator?
dry sump it!
Yup, what @Dingo said.... this is basically the easy step one step 2 will be pulling you oil pan off and changing the oil pump... I'd rather not do that if I don't have to but it's next up on the list... Hoping this worksThey must make an oversized pan ?? is that off the table at this point?
dry sump it!
Closest I ever got to one of those was my '99 Civic SI sadly it burnt a hole trough one of the exhaust valves on the way home from snowboarding one day 🙁 drove almost 60 miles home on three cylinders it sounded more like a Subaru than my current Subaru does LOL
Until it was stolen, right? Based on the sample size of friends-with-GSRs, they're all stolen eventually.
Years back just before we were married, my wife had a GSR. Stolen while we were having dinner at the mall.Until it was stolen, right? Based on the sample size of friends-with-GSRs, they're all stolen eventually.
Nope not stolen lol. Where I live, car theft doesn't really happen. I still did have layers of deterrent though.Until it was stolen, right? Based on the sample size of friends-with-GSRs, they're all stolen eventually.
Bold move with a cowl hood AND a scoop through it!Seen on the mean streets of Linden this morning.
If Mad Max drove a Nova.View attachment 137698
