This may be a stupid question/idea and I am not sure if I posted it here before so figured to ask the more intelligent audience here.
On days like today I stress about the power going out or even worse the sump pump failing. I have it on my to do list to get a backfeed panel installed by an electrician so i can plug in my generator to the house. This would not solve my problem if the sump pump fails. I know i can also get the whole backup sump bump battery system thing too but wondering if this idea would be a less of a hassle.
Since my basement has a french drain, would it be a bad thing to add a few bricks or create a barrier on the floor enclosing the sump pit, to redirect the water back to the french drain? This would only be for "emergency" purposes obviously, up to the point that I can repair or replace the pump and/or get the generator running to start draining the pit.
I realize it's probably counter productive to send the water back to the same place I am pumping it out of but for a short period of time it would prevent the spillage onto the basement floor for times when no one is around (ie power outage or pump failure in the middle of the night).
Idea would be to get a few leftover bricks that someone might be getting rid of, and section off like the picture shows. then seal it to the floor and in between with construction adhesive/silicone and seal off the inside part of the bricks with the same basement waterproofing i have on the cider blocks.
on a side note replacing the pump soon( *edit - and check valve) is on the list especially after this bad storm season. I think its about 5+ years old since I replaced it last.
Discuss.
