one piece crank
1pc Cranky
I think I'm good. I have stopped buying, and now focused solely on riding 😛
If nothing breaks, maybe a new bike in 2024?
went on very easy, weight is 1.56 lbs. Half mile ride hitting all gears up and down a few times and all seems good.That's light than xt or gx
Which drivetrain will this go on?
Do keep us posted on shift quality and durability.
all the gears come off individually and could possibly be flipped upside down, no?not sure i understand the question(gears having a right side up), the cassette only goes on one way
I think so, because I always put the writing to the outside, I seem to remember reading that somewhere.If they fit both ways, and aren't marked, they are probably ok.
is the chain directional? 😉
I'm asking because I see some people take it apart and clean it up, can you reassemble the gears a wrong way?
I would keep the numbers of teeth (if printed on each sprocket) facing towards the chain.all the gears come off individually and could possibly be flipped upside down, no?
Looks like a shimano derailleur?went on very easy, weight is 1.56 lbs. Half mile ride hitting all gears up and down a few times and all seems good.
I'll give it a longer ride tomorrow. seems fine though. now a question, do all those gears have a right side up or doesn't it matter?
yes, came with shimano cassette and derailleurLooks like a shimano derailleur?
after a twelve mile ride today it's performing perfectly. Did the OOS Lungbuster up Laurel trail and it shifts fine.went on very easy, weight is 1.56 lbs. Half mile ride hitting all gears up and down a few times and all seems good.
I found the mips helmet fit better than the kineticore. Hope it works for you.I remember someone recommending this helmet. Maybe @Ryan.P It's been popping up in my FB feed. Ordered today. This is to replace a POC Tectal Spin that just doesn't work with my head and Oakleys.
Hope so too. I haven't received it yet. Didn't like a previous Bell MIPS because it moved too much on my head.I found the mips helmet fit better than the kineticore. Hope it works for you.
Pro tip - I use a very thin Do-rag or bandana for sweat control and for tightening up the fitment of a helmet. Makes everything feel more secure to my head. Maybe worth trying...Hope so too. I haven't received it yet. Didn't like a previous Bell MIPS because it moved too much on my head.
