did he actually take the battery out to test it? if he tested it without taking it out i would disregard those results, the printout even says 'out of vehicle test' so the results will be inaccurate if it was not in fact out of the vehicle.
that said i am not aware of any way to determine state of health with a multi-meter, i have a cheap battery tester that i use on our cars, and 400 does seem low to me for a 625 rated battery, also check your battery for its actual rated (din) as i have seen people run the test without telling the tester what the expected rating should be.
If you are near union you can swing by and ill run a test with my unit while its in the car, takes <1 min (maybe 5 if the battery is buried in the trunk
