The DIY thread - DIYourself
while this is a good idea in theory, im pretty sure this is not available in NJ anymore, at least i havent seen it at any of the pumps in over 10 years.
instead i put ethanolshield in the can before filling up, so far so good.
depends on you capable you are at adjusting them, not that the OEM one guarantees perfect adjustments. I usually buy the cheapo ones for myself but if i work on someone elses machine ill buy the nicer one to avoid the chinesium problems.
I keep forgetting that. Not sure why it's not available, at least maybe there's some available more near farm country?
It's not available everywhere here either, but a few gas stations have it.
I grab it when it goes on sale at Lowe's or HD. yes it is expensive.
oh wait, I have battery equipment now 😉
Aviation fuel is an option - esp for chainsaws.
Never had to deal with a carburetor before, how difficult is to clean the carburetor on a Tecumseh 8.0 hp snowblower motor? Yesterday I spilled more gas than I actually used, not to mention the random stalling out at the worst possible time...
It may depend on how old it is. I have a lawnmower I bought... 15 years ago - maybe 20? ...and every few years it doesn't want to start, so I take the carb off, take it apart, clean gunk out of it with carb cleaner and put it back together and back on the mower. Really basic - no rebuild kit or gaskets or anything - just some cleaning. Then it will start on the first pull.
I don't buy anything special as far as gas goes although I do put a few ounces of Stabil into the 2.5 gal can prior to each fill up. I'll fill the can every year and a half or so. Non-ethanol gas isn't available near me, so it just gets regular gas.
Bear in mind, that is the ONLY service that mower ever gets. Ever. Each Spring, it's a bit cantankerous about starting but then it starts reasonably easy for the rest of the year, typically mowing once a week or so. Still on the original spark plug as far as I can remember. I have pondered getting a new battery mower, but it's hard to justify when the old one just keeps working with minimal fuss.
The El cheapo one that I put on my mower has been fine for years. Of course now I jinxed it.
I have a 6hp tecumseh. I bought a $25 dollar one one Amazon. It works great. Came with a bunch of extra stuff. New fuel line, spark plug, ect....
I like to think I would be capable but I just don't have the time nor inclination any more. El Cheapo it is then...
Pretty sure nj law requires some sort of ethanol (I'd be thrilled to be proved wrong on this) but even working in South Jersey bumbleland I don't see any real gas anymore. Maybe if you cross the border to Pa or ny but who has time for that?
I work on small engines on the side. I end up buying an Amazon/ebay one for $20 most times since cleaning the carb is kinda hit or miss IMHO.
Based on this I would lean towards the real one but it's your time and your money
Amazon took my money already, I'll have to live with it...
Also, I'm considering buying the snow plow attachment for my John Deere lawn mower. Considering the very likely chances that if I go through with the purchase NJ will experience a uninterrupted summer until 2075, is anyone willing to chip in to what seems to be a very expensive bill?
plow or snow blower?
you will be very disappointed with the plow - it needs wheel weights and chains - and then it can only plow 6" of snow,
so you do the edges in the middle of a storm, then push the middle out to the edge, then do the edge again.
Better off getting a dedicated snow blower - and run the carb dry after each use. IMHO of course
(I had the plow attachment for my old garden tractor - that was my experience)
Now, I have an F911 that takes a 72" snow blower attachment - if I ever see one on the equipment surplus sale....
Also, I'm considering buying the snow plow attachment for my John Deere lawn mower. Considering the very likely chances that if I go through with the purchase NJ will experience an uninterrupted summer until 2075, is anyone willing to chip in to what seems to be a very expensive bill?
Just get a bike box and ….
I already have the blower, hence the need to replace its carburetor...you seem to fail to realize that I do not think or act applying any rational criteria.
BTW, only 6" is not going to do it...
I backed out of my garage with my Kuat bike rack in the "trunk loading" position during the last storm. helped with breaking up the top ice layer to make shoveling easier. I'm sure i could jerry-rig a rear plow with a sheet of plywood attached somehow...
I hate doing anything plumbing related. Something always leaks and requires 3 trips to the hardware store.
What I thought was the toilet tank sweating a little recently and dripping on the floor of our master bedroom bathroom turned out to be the gasket between the tank and the bowl. Went to local Ace hardware instead of HD or Lowes because I didn’t feel like dealing with the crowds this afternoon. Lucky for me they had the Kohler OEM spec one in stock but I got one of the generic ones “just in case”
When I went to take it apart I realized the tank was actually a little loose somehow and I didn’t need to use much effort to loosen the bolts holding the tank down. I’m guessing after a long period of time with the tank slightly moving back and forth it wore out the gasket.
It was a bit of a PITA to get the old one off the tank but the new spec one has a better design and fit perfect. Reconnected everything and just needed to snug the water line and fill tube a few times to get it to stop dripping from the water connection.
I probably should have grabbed a new water line since I had that off anyway I’ll swap that another day. Or I’ll probably forget until I see a drip but the last 4 hours nothing dripping.
$17 and only took an hour. And only the one trip to the store. Calling it a win.
Operation carburetor on the snow blower was a full failure. I replaced the unit, reconnected all the hoses and the only wire...it now doesn't even try to fire up.
Being absorbed by other more important issues in my life right now I stupidly left the snow blower outside.
Since it has always been garage kept so far, I suspect it may not even be a problem directly linked to the new unit...leaving dry in the garage for a while and will resume the investigating the issue later this week. I know, it's such a gripping story...
FML
FML
so does it crank over but not fire? did you try flooding it with a bit of starter fluid to see if its a fuel issue?
Typically only 1 of 2 things - no fuel, no spark. Open the bottom screw on the carb see if your getting fuel dripping out.
While leaving the machine out in the rain long term isnt great, just one time shouldnt cause a big issue.
But now since snow season is over maybe its not that important - until the next time it snows LOL
Fuel gets there, does not start. Tried a new spark plug but nothing. I may not have grounded the key switch correctly is my best guess. I may have a chance to get back to it tomorrow. definitely don't want to put it away for the season before fixing it, it would most definitely cause a snowmageddon in December (or May given my recent luck).
