TonyK
2015 Specialized FatBoy (Large size - 5'-9" min. height recommended)
The bike is known as the "Fatboy" and was maxed out when built - check out the component list below. I’ve ridden
many types of mountain bikes, but my Specialized Fatboy has been the most fun,
hands down. This thing just eats up any terrain—snow, sand, mud, whatever you
throw at it—and makes even the ugliest weather days feel like an open
invitation to ride. IT has a Rockshox Bluto fork so it's not just for snow riding. The shock
makes it great for MTB riding over rocks and roots, etc. And these fat tires give incredible traction and stability, so
you’re gliding instead of grinding, and it’s surprisingly light and responsive
for a fat bike. Whether I’m pedaling through snowy trails, dealing with
spring muck, or riding in sand, the Fatboy never fails to be a fun ride.
If you love mountain biking, this is one bike you’ll want in your stable.
Price: asking $950, Or Reasonable Offer
Contact me using my gmail address. tonykulesa at etc.
Components:
Frame: Specialized M4 aluminum, fully-butted tubing. Color is yellow.
Suspension Fork: RockShox Bluto RL, Solo Air spring, Motion Control damping,external rebound adjust, , 32mm alloy stanchions, disc mount,
Seat Post Dropper: Command Post BlackLite, single bolt, remote adjust lever, 30.9mm, 125mm travel
Rims: Specialized Stout XC 90, disc, alloy, single wall, 90mm wide, hookless design, 32h
Front Quick Release: 15mm thru-axle for 150mm hub spacing
Front Hub: Specialized Stout XC 150, Hi Hi disc, double-sealed cartridge bearings, 15mm thru-axle, 32h
Rear Hub: Specialized Stout XC 190, Hi Hi disc, alloy, sealed cartridge bearings, QR, 32h
Tires: Specialized Ground Control Fat, set up Tubeless, 120TPI, 26inchx4.6inch
Rear Derailleur: SRAM X01 Type 2.1, 11-speed, carbon cage
Shift Levers: SRAM X01, 11-speed, trigger
Cassette: SRAM X1, 11-speed, 10-42t
Crankset: Race Face Next SL, PF30 BB, 100mm spindle, 28T direct mount ring
Stem: Specialized XC, 3D forged alloy, 4-bolt, 6-degree rise
Handlebars: Specialized, 7075 alloy, 8-backsweep, 6-upsweep, 10mm rise, 31.8mm
Grips: Specialized Sip Grip, light lock-on, half-waffle
Saddle: Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
Brakes: Shimano Deore XT, hydraulic disc, metallic pads w/ fins, Ice-Tech rotor
Brake Levers: Shimano XT, hydraulic, reach adjust
Weight: 31.9 lb
(Pedals not included)
Components:
Weight: 31.9 lb
