iman29
Saturday had to work on the one thing I hate the most. Plumbing stuff. Again.
Nothing too complicated but to me anything that has to do with a drain, valve, water supply or something that can leak I know will
Be complicated no matter what.
I probably posted this before but the inside shutoff for the hose bib was formerly slightly leaking. It’s located above the sump pit so it just drips in there all last summer and no big deal. Saturday my son needed the garden hose and turned the inside valve on and it’s pissing water everywhere. Plus the outside valve leaks too. I always assumed that I needed so cut pipes and sweat on new valves then I had a thought. Can I swap the valve body itself. ? Hmm.
Went to Lowe’s got a few hose bib and stop valves because I could not see the size on current one. While the hose valve was correct the indoor shutoff valve was not. So to try and avoid multiple trips I was able to take the old valve out to bring with me. Of course this required to shut off the main to the house (which was replaced with ball valve 3 years ago by an emergency plumber when the dishwasher installers broke the valve ).
While at ace hw store I explained my plan but we could not take apart one of the new stop valves to check the size. His last comment was he didn’t think it was going to work. So I bought two and crossed my fingers it would fit.
Used a pair of pipe wrenches to take out the valve body and BINGO! it fits. Went to install it and tightened it down but the old plastic seal washer was too brittle and cracked. Took it back apart and made some threads out of teflon tape and wrapped the valve base and reinstalled.
Done!
And since I had the hose bib valve I did the same but this was much easier swap and took less than 10 minutes. Mostly walking back and forth shutting off and turning back on the water.
So for $35 and 2 hours I fixed it. And now I know how to fix the leaky shut off valve and hose bib on the other side of the house hopefully it’s the same process. I think I was more satisfied that the hw store guy said it wasn’t gonna work. Learn something new every day.
Done!
