Hartshorne/Huber Conditions
Unless the park is closed it’s probably better not to know. It can be a bit unnerving if you ever see someone in the lot putting their camo on, getting their weapon and heading out in the same direction you’re riding.
I see that all the time at six mile run. They bow hunt in the fall. Chances are they are leaving the park by 10am anyway, those guys are there before Dawn.
There is a sign with the dates for deer hunting at the trail head on Navesink Ave. I'll take a picture of it and post it up. I'll probably be there some time early this afternoon.
Found this the other day.
Trails we're in decent shape. Some of the lower lying areas of Rocky point and Laurel ridge had some big mud sections but 90% of the trails we're fine. There was a huge downed tree on Rocky point. And apparently" trail head" was not what I assumed..I was disappointed...lol
I think this is the tree you were talking about on Grand Tour. It uprooted taking the trail tread with it. There were 3 other downed trees that I came across. The others were all on Rocky Point.
You can tell I am not a photographer. That is a terrible picture. The tree is massive and the hole where it was is actually quite deep.
I did TM there today. Ridable today with some slick spots. Rocky point was good.
What kind of work did you do? Looked like a bunch of new drainage channels were cut into the low areas and some of the muck was removed. It seems like there were more trail markers, too.
What is the proper approach to fixing this type of situation if found on your local trail? Do you cut into the bank on the left or do you fill in the hole on the right? Thanks
The one I'm talking about was across the trail blocking it. Same size tree.
  • Like
Reactions: Tim
I would think cutting into the bank and using some of that material as backfill for the hole would work.
