Very boring thread
Status
Not open for further replies.
The headset and bb specs should be listed not manufacturer website. What year/brand/model is it?
Also, on Cane Creek website you can enter the year/brand/model and they tell you what products are compatible.
Dude, is the eccentric? If so, it’s a non boost frame. We’re you aware of that?
What do you mean?
per the site
Material: AL6061-T6, custom formed and butted tubes
Sizes: frame available in 3 frame sizes (16”, 17.5” & 19.5”)
Recommended fork travel: 130-150mm
Head tube: integrated tapered IS42/IS52
Fork compatibility: fits forks with standard 1 1/8” or tapered 1.5 - 1 1/8” steerer tubes
Head tube length: S size: 105mm, M size: 115mm, L: 125mm
BB: threaded 73mm
Biggest chainring: BOOST only up to 32t
Front derailleur: not compatible
Seat post: 31.6 / seat clamp: 34.9
Max seat post insertion: 270mm (S), 300mm (M & L)
Cable routing: stealth cable route with rubber grommets in seat tube for dropper post
Tires: designed to fit 29" but works also with 27.5” wheels with tires up to 3.0"
Maximum tire size recommended: 29 x 2.5", 27.5 x 3.0”
Disc brake: post mount disc brake mount, max rotor size: up to 185mm
Hub spacing: 148x12, NS axle included
Weight: 2.2kg (M size, w/o axle)
What do you mean?
per the site
I was looking at the eccentric alu evo 27.5, as the picture on their website of that model seemed the most similar to your electric panel ornament...cough...bike frame. I guess it’s a typo anyway, what would the 27.5 frame be 142x12 and the 29 148x12?
alright so fork is getting here monday, I'm going to cannibalize the ragley temporarily, but I need to order parts for this bike to get it on the trails. Here is my list
I have forgotten tires......
I'll be carrying over:
Brakes(calipers and levers)
Seat
handlebar
stem
pedals
cassette/ derailleur/ shifter
aside for tires, I'll need spacers and... what am I overlooking?
alright so fork is getting here monday, I'm going to cannibalize the ragley temporarily, but I need to order parts for this bike to get it on the trails. Here is my listView attachment 118795View attachment 118796
Seat
handlebar
stem
pedals
I have handlebars you can use
29 I'm going to end up ordering off of chain reaction and I'm going to look at droppers, don't tell Ali lol
I have a set of 29 X 2.4 ardent that might work with a patch For one tire. I have a spare set or 2 of 27.5 tires but not sure I have as many 29. I will check the basement and shed tomorrow
Seat
handlebar
stem
pedals
How do I know if I picked the right caliper mounts? fork and frame are 160 direct mount, for has a 203 max and the frame has a 185 max, just looking for more leverage to delay getting zees.
Status
