Morris MUA is well water. There is basically nothing in the water other than water. If you're super close to the distribution point you can find traces of Chlorine, less so if you are further away. But it keeps your camelbak clean. The wells I worked at were pretty much just wells with chlorine injection. There could be others that require more, but probably not. Not much happens to municipal well water in North Jersey. There's at least one well I know of that's near enough to a former WW2 runway that they have to blow air across the water to remove volatiles from the water. But that's in Essex County.
