Thanks. I has all the connections. Problem solvers, wolf Tooth, cheapo Amazon brand. The sram x worked.@jShort nothing stopping you from throwing a piece of brass shim under the matchmaker (on either the brake lever or shift lever).
*edit* oh whoops, old brakes. I've got an I-spec to SRAM dealie if you want it
*edit edit* it's a LH so it's offset to the left, not right. But I do have a discrete (directly to shifter) clamp for SRAM if you want it.
