Washed our bikes after this mornings ride. Then decided to do another, then another. Things escalated quickly. I’ve never had so many bikes clean at once.
Installed some new grips on one of the bmx race bikes and tightened a couple loose spokes on the GT DJ.
Had a slow leak on the rear of the gravel assault bike-
Figured I’d start with refreshing the Stans since it’s probably due-
As I unscrewed the syringe from the valve, the valve but nearly came off.
Ah, okay. Cinched it down, and we’re good.
Was also going to clean and lube the drive train, but it’s looking good with the factory lube still on it.
Amirite @extremedave and @SheldonBrown?
Not my bike but I replaced my old tool box. After so many adventures and good times, I was sad to see it go so I meticulously peeled off a few stickers and glued them to the new box.
Some of these stickers are more than 25 years old.
Post trip bike teardown revealed one seized suspension bearing and two well om their way. They got replaced, all pivots lubed bike cleaned up. New tires and brake pads, bled the brakes and this is what came out of them...😳 May have waited a bit long for this job... .
