Looks like coal is the real answer......we'd need to stop and fill with water too, cause steam engine.
Or storing hydrogen at 5,000psi might weigh a bit for the fuel cell crowd.
to interpret this, energy mass vs volume (density)
the scale isn't the same on both axes? (yes, the plural of ax and axis is a homonym, i may start using axiis)
looks like ethanol has 70% the energy density of gasoline.
it needs to be distilled - which is easy enough - just capture methane from a garbage dump.
and if you are wondering, no - there is no E100, except in missouri, and they don't burn it.
Can cars run on alcohol?
We look at the science behind powering a car on alcohol alone
					www.arnoldclark.com
