Winter projects time. I finally sucked it up and rented a garage to store a car so I have a proper motorcycle area. First up is the Apriia. I picked up a programmable ignition/power valve controller. EDIT: While it has carbs, the bike is more sophisticated than you'd expect. It has a throttle position sensor, so the timing curve has 3 dimensions. It also has air selonoids that can be used to make subtle changes to the fuel-air ratio. The new controller includes an input for a quick shift sensor. It also lets you switch between two ignition and powevalve curves while running. It adds an output for a shift light too. It came with the same stock map my bike has already, as well as a 'race map for pump gas' whatever that is.
A friend gave me a couple pieces of race bodywork he had laying around. Coincidentally, the group at NJMP announced a 'small bike day' next season, so I know what i have to do...
