I have not tried but also heard this works. Makes sense that it would.He said it worked the same but didn’t waste a bunch of cleaning product and the device stayed clean. Anyone try this?
Makes sense especially to save cleaning product, you would still have to wipe clean the ultrasonic tank though. Mine is stainless steel with a drain, it takes about 10 seconds to clean. Will try.That’s one ugly stripper
Read a review from a guy who was putting small parts (not bike parts) in a ziplock baggie full of his preferred cleaning product and putting that in his ultrasonic cleaner which was full of water. He said it worked the same but didn’t waste a bunch of cleaning product and the device stayed clean. Anyone try this?
It's is so easy with the Silca set up. I probably rewax way too often, and then reuse my quick links 😬So much faster. View attachment 268623
New xt chain
Degreaser than some denatured alcohol.
Did that yesterday at work.
Wax this morning at home
I reuse shimano quicklinks without issue, SRAM flattop 12 speed quick links, have broken 2 after reusing so no more.It's is so easy with the Silca set up. I probably rewax way too often, and then reuse my quick links 😬
Only issue I've had with quicklinks (Shimano) and wax is that wax get in the little groove where the opposite link is supposed to snap in, then it does not snap in. A quick clean of the groove and they're snapping like a turtle...I reuse shimano quicklinks without issue, SRAM flattop 12 speed quick links, have broken 2 after reusing so no more.
Snagged a Silca setup in the sale frenzy.
If anyone is wax curious come get my crock pot for free, it even includes some old wax!
Dude those things are like $30 each now. How about a lithium battery instead?I'll give you $1 to wax that 9-volt battery.
Just throw them in the Passaic. They’ll dissolve like sugar cubes.I have a few dozen e bike batteries I need to unload. I was gonna throw them in a river but that crockpot might be more fun.
I can imagine that the wax is hardening on contact, considering the temps. So probably not getting into to the parts needing lubricantSo I found a limitation with waxing: sub freezing rewaxing
its been cold and I had two broken links in the past week. It would appear the pin was seized in the roller which makes me think wax isnt getting in there. With the drip refresh, being water-based, I am guessing it isn't getting far enough into the roller to be where it actually needs to be. Could likely have been mitigated by hot wax in this cold period or putting bike inside to warm up before drip wax.
Salt could be an issue to but I transport my bike to and from in my car and only had one sloppy ride.
Unlike proper lube?I can imagine that the wax is hardening on contact, considering the temps. So probably not getting into to the parts needing lubricant
I use a hair dryer to assist with cold weather drip wax. I'll spend a couple minutes preheating the chain and then a few more after the wax is on.So I found a limitation with waxing: sub freezing rewaxing
Salt could be a issue to but I transport my bike to and from in my car and only had one sloppy ride.
Offset by cleaning entire drivetrain a bunch in the winter, can just put bike inside for a lwhile before dripso much for waxing saving time . . . . 🙄
