gtluke
The Moped
Well what's nice is that you can have a few loops in different colors, or extensions of loops and shortcuts. So if you are feeling good add some, if you get a flat, subtract some.
I think you'll be easy Norm, in bike route toaster just select GPX instead of TCX.
Then:
Where to - Saved Rides
Select your ride
Setup Map
Pick your color, click the box that says "show on map"
Hit map
it shows up on your map, just to confirm.
Hit the left button, it returns you to the map setup feature and just hit Okay. You can now turn the navigation on and off and the map will just stay there.
ATTENTION, MAKE SURE YOUR FIRMWARE IS UP TO DATE.
This was impossible to do on last year's firmware.
If your ride doesn't have the "map setup" option, something is wrong. This is what I struggled with Utah with last night. The google maps tool screwed up the .gpx
Then:
Select your ride
Setup Map
Hit map
