what are some good trails to go on? either tomorrow or friday i want to try and ride most of them.
Take a tour, enter the gate, make left at opening in fence and make immediate right onto Animal Shute, right up it exits on a road bear right, right along tree line on right and just before the crest of a short hill make a right onto Warthog (tail end). Continue on the white blazed Warthog until you exit through a fence onto a paved path, approx 2.5 miles. Wathog winds around the perimeter of the parking lot. Bear right on the paved path and make the next right, you will pass the Otter Slide on the left then you will see an orange blaze indicating the start of the Otter Slide trail. Follow otter slide as it switches back up the hill, near the top you will come to a boulder bear right onto Rhino, Watch for hunters, as a matter of fact I would only ride Rhino on Sundays when there's no hunting, Rhino has occasional Orange and White blazes. After about a mile Rhino will dump you back onto the top of otter slide. Continue following the orange blazes onto Tanks, Tanks will pass through a fence and bear right at the cage onto cages as it crosses a quad trail. Cages twist around through a field and over a rock ridge crossing the same quad trail and eventually dumping out onto a road. Straight across the road is the entrance to Tiger Pen. Continue through tiger pen untill you ride over 8 cinder blocks and through a fence to Tigerfish rocks. This is the main intersection at the top of Jungle. Immediately towards your laft and along the fenceline is goat. Don't take that. Continuing with the orange blazes straightish is Fish. Bearing towards the right and through the fence with the sheetmetal on it is the start of the brand new trail Boon.
Here you have a choice, continue on fish, a tight twisty trail along the ridge until it ends at the yellow blazed Hippo trail. Or bear right through the fence and make a quick right and left on the road to get to Boon. Boon isn't blazed yet, but climb it to the top and then back down as it parallels fish on the opposite side of the road. Boon features several technical rock sections and some you won't find. Boon exits onto the powerlines where you bear left cross the road and drop into the yellow blazed trail on the left. Ride this back to the intersection with fish.
From fish make a left onto the yellow blazed Hippo trail, from Boon continue straight on the yellow blazed Hippo trail. A couple of quick switchbacks and quick rocky descent and climb will pop you through another fence, Follow the yellow blazes as Hippo switches back and forth to the road, Bear left pass a sinkhole in the road and make an immediate right onto lower chute. Ride lower chute back to the fence cut where you started.
Got that?
I'll probably be out there several times this weekend, PM me if you want a tour.
