Well written post and I can't disagree with any of it. I'm not actually asking if clipless is better than flat, I'm 100% certain it is. As a road cyclist, I'm 100% comfortable clipping in and out, so when I got my fatboy I threw clipless pedals on immediately. I'm actually wondering if maybe I jumped the gun a little bit and I should switch back to flat for a few months as I get used to being off-road, which is essentially the order you describe in your post, learning to ride off-road on flat pedals for some time before switching to clipless.
Been on clipless for a year now, so a bit of an update.
I would suggest since you are already comfortable being clipped in I would stick with it. I'm hard pressed to recall an incident where I couldn't pop out of the pedals in time. I would suggest keeping the tension on the lowest setting at first. In addition to what I wrote I think clipless is better with not getting jarred off the pedals in rough terrain. This is REALLY subjective but I do think there's a difference. Oddly of all the differences my thought right now is the pedal clearance advantage is a bigger confidence boost in the rocks than being able to jump off the flats.
