This
This one time in band camp…damn, vibraphone mallet?
(my kid played in HS marching band)
plumbing work always = mandatory 3 trips to the store for 3 versions of the same part and then I never get around to returning whatever I didnt use.Kitchen Sink Drain putty re-do. I was ahead of the game this time. Last time I put silicone grease on the metal ring/drain deal (not corroded this time), My container of plummers putty had enough to use because I triple sealed the shit out of it....3 separate uses this time, a record! Went the extra mile and cleaned all the scum and disgusto out of all the pipe sections and into the wall connection. 99% done and the last thing to tighten (just snug) was the metal 1 1/2" ring to the drain line out. Light channel lock squeeze and crack....I had 6 pieces (uggh). Thankfully they sell just the nut and new seal vs buying some random drain kit just for the nut. Bag says Heavy duty....yeah BS. $5 is a win I guess but a bit of WTF when I was already DONE and cracked the last piece thus causing a whole "trip to Lowes" event. so close to flawless execution. Next time maybe......
Its as though you woke the gods and they realized I had gotten away with one. I checked and just a slight wet. After review....the only connection I didnt' mess with (because it didn't want to come apart)....it leaks...just a little when you run the sink a while to do dishes. The crud seal must have broken with my work. Sooooo I'll be back out for parts. This time I'll be replacing the cobbled together bullshit I have. I'll keep and use that $5 nut though.....if only out of spite.plumbing work always = mandatory 3 trips to the store for 3 versions of the same part and then I never get around to returning whatever I didnt use.
Oh how I hate thee (periodically) kitchen sink.
The @Patrick method reduces this to 2 trips, one of which you’ll make eventually:plumbing work always = mandatory 3 trips to the store for 3 versions of the same part and then I never get around to returning whatever I didnt use.
Buy the part you need and all adjacent parts as well.
Then return anything unused on your next trip. #SoPro
Oh you guys, that is so cute...the only way that worked would be to buy the whole HD catalog on the first trip. And even then, I'm not so sure.
Granted you own the right compressor...Love me some air impacts. Battery is close, but nothing beats the true ugga-dugga power of air.
I love this IR impact gun. While doing some work a few months ago, she just started spinning on here own, which meant it was time for a rebuild. $60 and about an 1.5 hours its good as new!
I have two that - tried to repair 1 and failed, not interested in trying the other.
who wants all the parts - prob only 40 years old, so just broken in.
parts are available!
What size is the die?
The correct answer is buying bigger compressor and new tools to go with it, keep the old ones as spares.You guys make me both want to put my air tools for sale on here (no longer have a big compressor) but also make me want to keep them.
My IR impact will outlive human society, I don't expect that from my perfectly fine Ryobi.
Need a bigger house...
