Laurel Trail is all clear now, I cut this one out today.
Hard as hell wood, 700 strokes with the Silky saw.
after 10 I knew it was a tough one and decided to count 🤪im more impressed that he counted the strokes!
that's what she saidafter 10 I knew it was a tough one and decided to count 🤪
Double pond trail: boardwalk section is almost completely overgrown which makes staying on the planks a pretty difficult task. You can't really see it anymore. Also nature Jim's bridge section is completely under water. Had to turn around. Some down trees here and there but all easily passable (at least to the point where I turned around)
Pumphouse: coming from south end where pumphouse splits with boulder garden is closed apparently. There's a sign there saying closed for trail maintenance and to use boulder garden, but they make no mention of the fact that bikes are banned on boulder garden... Since I was stuck and had zero interest in going all the way back I went pumphouse anyway to see what was going on. They're rebuilding that rock section that crosses the stream towards the lake. Bridge is gone and rocks are piled on each end. Easy to walk by it as it was pretty dry but if it rains and you go this way you're going for a swim to get across.
No idea how long the repair will take but if history is any guide you can ride pumphouse again sometime in 2024
well that's great news that it's not official park business. that means it will actually get completed soonPumphouse Bridge Build: 10/8/22, 10/15/22, 10/22/22
Mountain Bikers Wanted! NYNJTC/Black Bear Cycling/JORBA Volunteer Trail Work: Wooden Bridge build on Pumphouse Trail (Renamed Lake Loop Trail) to replace the old rock bridge. Bring sturdy shoes, water and snacks. Meet at 9am at the rock bridge on Pumphouse Trail (Renamed Lake Loop Trail). Best...www.mtbnj.com
Looks like unfinished business.Looks like someone improved the lousy stream crossing at the end of Banker Trail, now it has a bridge. Thanks whoever!
View attachment 201947View attachment 201948
sort of, but.....better than it was thoughLooks like unfinished business.
Is it sat directly in the water? Looks to be damming debris.Looks like someone improved the lousy stream crossing at the end of Banker Trail, now it has a bridge. Thanks whoever!
No, it's on rocks and water flows under pretty wellIs it sat directly in the water? Looks to be damming debris.
